260 Prowler Water System
Recently bought a 260 prowler and looking to figure out how the water system operates. Flipping the switch in the cuddy seems to not do anything except light up. I believe the pump is on the port side in the front of the engine compartment? is there a float in the tank that the pump wont run unless it senses water level? not looking to fill the tank with water with no way to get it out...
Forum Regulator
I owned one about 20 years ago. IIRC, there is a drain on the tank. There is no float in the tank. You could have a blown fuse or bad pump if you don't have the pump turning on. I do believe the pump will turn off when it builds pressure though. Open a faucet, and turn the pump on, so see if it has built pressure.
