Prowler gas tank
Prowler gas tank
Is there any type of anti syphon valve in the fuel tank on a 260 prowler? Hurricane Ida heading our way so I pulled the boat from my lift and put it on the trailer in my driveway. Want to be able to get to the 50 gallons of gas in there in case I need it for my generator.
Thanks.
Thanks.
Charter Member #1472
you can always get to the pick up in the tank under the back seat, there's an access panel with about 15 screws and there's your tank fittings.
tmalone76 (08-29-2021)
Why wouldn't you just put a hose down the fill tube and suck it out that way? Opening up the tank is risky business, especially with lightning and other things going around in a big storm like that. I don't know, am I wrong?
yes. it is a small panel, you wouldn't have to open the tank. not sure but the should be another bung there for twin engines or just take the fuel line off that feeds your engine and put a hose on it.
Thanks.
Helmwurst (09-01-2021)
