The "Blown Formula" Sonic Project !!
#211
Right, no Christmas card this year (or ever!!). I hope you are correct on the speed. Last summer even with the problems & one engine only turning 4500, I was running 75. I hope to be able to move up to 28" props or more from the 26" I was using. Patients is the key... I keep telling the wife that!!
![Ernaehrung004](/forums/images/smilies/ernaehrung004.gif)
#212
I launched yesterday...... my preferred ramp was closed so the alternate was necessary. The windf was blowing hard across the ramp.... so hard the waves were splashing into the engine bay vents!! Hit the key...... Bam!! it started right up!~ Great.... no for #2..... it started great too. I just quickly adjusted the timing on both engines, checked the fluid levels again, closed the hatch and backed off the trailer. Idled around for awhile & rechecked everything for leaks.... I had a transom water leak around the transom assembly last summer. Everything looked good so closed up again & headed out. Everything worked great, no sproblems.... it worries me cause this has never happened!! So I am cautious and suspicious too!! I drove around some, sat on the beach and had a couple of beers with friends, everyone said the engines sounded great, watched the "babes", etc. for about 5 hours...... checked the bilge again.... no leaks yet. Again, started with a "flick" of the switch which it has never done and off we went. No problems!! What a relief. Of course I still have prop selection problems to keep from blowing out coming up on plane, but otherwise it was "anti-climactic" after all this time and trouble. I stayed consevative and never went over about 3700 rpm.... I want a little runn time to get comfortable with the engines as being reliable before I nail it to see it's performance. I'll let you know soon.
George![Kiss](/forums/images/smilies/more/kiss.gif)
George
![Drink](/forums/images/smilies/drink.gif)
#213
Great To Here Everything Went Good. Kind Of Sounds Like You Dont Know How Too Take It With No Problems. I'm Sure You'll Figure It Out. Are You Running 28 Bravos On The -2 Imcos ? Keep Us Up Dated It's Been Along Road And Sounds Like Your Near The End Of It. But I'm Sure Their Will Be Something Else To Try. Good Luck John M.
Anarchy Powerboats
09-23-2008 12:45 PM
blown formula
04-29-2003 08:24 PM
