Toliet Trainning
Charter Member #37 /Moderator/Platinum Member
Toliet Trainning
. The generator plugs were bad. Thanks for everyones help. On to the next problem.
Now my toilet wont flush. I have two buttons of the potty one says Dry bowl flush and the other is flush with water. The problem I have is when you press the buttons the motor at the base comes on but it will not flush . Water is holding in the bowl . Any Idea How this thing works? It looks like there is a motor at the base of the bowl and there is a hose that comes of what ever that thing is attached to the motor. I KNOW this is not a pleasant subject but any help will be nice.
David
David
Champagne taste on a beer Budget
C. P. B. A. Carolina Power Boat Assoc
There is an impeller in there just like in the engine water pumps. It is either trashed or you have a blockage in the lines-EEEWWWWW. You need to take apart the base and check the impeller and then maybe blow through the lines-preferably not with your mouth
Thanks ,If I need a impeller were would I find one .
Thanks Again.
Thanks Again.
