Drive Ratios On 94 31ss
Can Someone Tell Me If My 94 31ss Came With A 1:36 Or 1:51 Ratio. I Can Not Tell By Looking At The Drives. Is There Any Way I Can Tell? The Problem Is This Boat Has Twin 502s And Has 14 1/2 X 22 4 Blade Props. The Boat Runs 46-4800 Rpm At 62 On Gps. I Would Like To See 5100 Rpm And What Ever The Speed Is At That Rpm Will Have To Do.
Re: Drive Ratios On 94 31ss
proman how you doing, email joe at [email protected] tell him i told you to he will have your answer to get that bad boy to 70
They came 1.5 stock. Clearly they have been changed if your spinning a 22P prop. It's amazing the thing will plane, go back to 1.5 and increase to a 28P 4 blade. Sweet spot will be between 26 and 28.
Sounds like it was set-up for a supercharger application and if so you may want to take a good looksy inside those drives when you change out those gears. That year with that power you should see upper 60's but that is about it.
Charter Member #655
My 1993 with aprox 485 hp and 1.50 drives runs low 70's at 5100 with 23 Mirage props
If your boat has a sail do you ride a horse to the ramp?
My 31SS came with 24P/Mirage & 1.36 drives. So that is what you have- 1.36 according to your data. You just need to change the top gears in the drives and then buy new props!! or just get some prop work done.
