Dry Stack Barn
Were looking for a indoor dry stack in So Fla. KW is too far. Our 400ss is 42 LOA 11W and 12.6 keel to radar.
I have called around but there is no published "directory" for these facilities. Any suggestions? Thanks
Forum Regulator
Did you check with Haulover Marine Center?
Welcome to Haulover Marine Center in North Miami Beach, Florida
A buddy had two diff 40ss drystacked in the FLL area. They weighed in about 16k lbs which I believe is about the max for most dry stack facilities to lift with the forklift (unless they have the mega forklift). Where ever you decide, make sure you check bridge clearance high and low tide in/out of where you wat to go which will clear your high point of the radar arch.
At low tide leaving/returning one marina we only had a few inches to spare.
Lots of nice places here in the Sarasota area.
21 and 42 footers
