speedo is gone!
Give us a bit more info.
GPS speedo?
Standard?
Check on the outdrive at the pivot point underneath. There is a yellow fitting and a small black hose that generally pops off after time or a certain speed.
How fast were you travelling?
GPS speedo?
Standard?
Or the intake on the drive got plugged if you hit a stick or something. If so a 7/64ths drill bit will do the trick for cleaning it out.
I say its a perfect time to replace it with a gps speedo.
