Go Back  Offshoreonly.com > Owners Forum > Sunsation
Any Super Charged Sunsation??? >
Old 09-13-2002, 09:52 AM
32' SUNSATION
Kanookstr's Avatar
Default Any Super Charged Sunsation???
Hello Felow Sunsation Owners. I was just wondering if theres a few super charged 288's out there, and what are they seeing for speed and at what boost???.
Kanookstr is offline
Old 09-13-2002, 01:20 PM
I run a 1995 288, originally equipped with the 500HP carb motor 74 mph, put on a B&M 250 PowerCharger with 5 lbs boost now runs 82mph. Really woke up the boat. Have over 150 hrs with the blower and no problems other than broken drives. Finally stepped up to a Teague built XR.
sun28 is offline
Old 09-13-2002, 01:51 PM
32' SUNSATION
Kanookstr's Avatar
Wow! it's tough on the drives huh? My 2002 weighs in at 4500 lbs. I didn't think it would be that hard on them? My Stingray has 200+ procharger hrs, but the drive held up good. All I did was add a billet marine drive cap and shower. What usually gave out on your drives? The Procharger is more forgiving on the hole shot, maybe it won't be as hard.
Old 09-15-2002, 04:17 PM
Lee
Lee's Avatar
I raced a full season in a supercharged 288 with a stock Bravo I drive with the exception of a drive shower and experienced no outdrive failures, That same drive is still in service to this day and that was 4 yrs ago.
Lee is offline
Old 09-15-2002, 07:05 PM
32' SUNSATION
Kanookstr's Avatar
Thanks for the input Lee. Which supercharger where you running?
Old 09-16-2002, 08:13 AM
Lee
Lee's Avatar
Non intercooled B&M, and it fits under the stock hatch using a HP500 (carb) flame arrestor with room to spare.
Lee is offline
Old 09-16-2002, 09:34 PM
Sunsation 32
Hot Boat Mag. did an article on one with a blower a few years back. It said firecracker on the side. I'll look in my archives and see if I can find the issue.
Old 09-17-2002, 10:33 AM
tmager's Avatar
I remember that article from Hot Boat. Last month I happen to talk to the sales guy that sold that boat, he said Tyler Crockett never did get the set up right on that boat. Last I heard the motor is no longer even in it.
tmager is offline
Old 09-17-2002, 02:00 PM
32' SUNSATION
Kanookstr's Avatar
Hey Lee. What were your boost numbers, Prop And pitch, and finally your WOT speed?
Thanks.
Old 09-17-2002, 05:38 PM
hirschy77
Default blower
Hi Guy"s , sorry to bud in on your convo, but I'm running the same set up as Lee!!~ 2001 27 convincor, 500hp w/ B&M250 7lb, boost , bravo drive, no failures other than sand in my low water pickup. All fit under hatch and runs superb!!! I have approx 30hrs on setup. 60mph at 4000 rpm, 83 at 5200. running with 27 labbed hydromotive. I believe theres room left. If your easy on the throttle out of the hole , and reentry, the bravo will hold up fine. I really like the 28 sunsation, and I think this would be a great setup for the money!!!!!! I also painted the blower to match the motor and looks awesome!!! Mark
Quick Reply: Any Super Charged Sunsation???
