Sink Drain/anchor locker drain?
Just got a Dominator and been going over the boat looking in all the nooks and crannys... it looks like the sink just drains to the bilge and doesn't have a thru hull to exit outside? Same deal with the anchor locker... water in there just drains thru and goes down the front V of the hull which soaks the carpet panels in the front forward compartment under the v berth... this seems like a terrible design...
Is this how other 32s and 288s are built? I want to come up with a drain system for them if so...
Also... I have 3 small bilge pumps all in a row basically between the two stringers in the engine bay... why three????
Everything else on this boat seems top notch as far as design but these two drainage issues seem super weird to me.
Formula ran the sink drain into the builge also on 292 Fastech's. I installed a 90° fitting underneath the sink drain and install the thu-hole. If interested I could give you the part number of the 90° fitting. As far as the anchor locker goes. Formula did make it thu- hole for that.
SabrToothSqrl (12-18-2022)
Interesting. I took out the pump and some lines, and faucet on my FasTech 292. I don't think the sink was used in 22 years. We use the bowl as storage for wet things lol, but really it's pointless to me. If I used it, I'd also rather it drained out the side than down the bilge! From the bilge it would only end up overboard anyway... so what's the point?! I should plug it up and take out the drain and other stuff that's only in the way of more usable storage. I'll take a look at it next week. Thinking of taking out the never used freshwater tank up front too. No real reason to keep pushing all that weight around.
My 292, the anchor "rope" locker (don't get me started on that) has a thru-hull.
Padraig (12-19-2022)
On the older 32 Dominators the placement of the sink was too low to run a thru hull fitting out the side of the boat so it had a drain hose that ran back under the wet bar and drained into the bilge. The water tank was a small jug tucked on the starboard side under the rear flip up seat cushion. It was removable so you could take it out and fill it up. Once the 32 changed to the SS/SSR hull bottom (2005) the whole cabin area became much deeper and those sinks had a dedicated thru hull drain.
In this picture it's at the lower right corner, a little difficult to see with the paint, right where orange meets black
