Steering Questions
Thanks Pat, I will look at the IMCO stuff.
Dave M, who makes the pod's you are referring to. Write now I have no room on the dash to add trim indicators.
Thanks,
Thanks,
Superboat can make the pod for you or look here....
http://www.livorsi.com/catalog/contr...m#THROTTLE_POD
Originally Posted by krakmeup
Currently do not have it - am looking at IMCO and Mayfair when I repower, of course Latham is nice but prob the most expensive. I look forward to some other responses too.....
You may want to consider upgrading to at least a twin piston "Add On" system before re-powering, like now...
Adding the external rams will strengthen the whole gimbal. That internal Merc tiller rig sucks and will loosen up.
If you run hard, and we know you do, the external rams are a big safety feature...
![Drink](/forums/images/smilies/drink.gif)
Patrick
Patrick
Ya, Zeigler systems offer short inside dimensions. It's good for narrow beam boats that have k-planes too. My ram is mounted outside of the k-plane and I would prefer it to be INSIDE the k-plane.
Lightspeed, from a strength standpoint, does it matter where on the transom the piston is mounted? I would think that the farther away the piston is mounted, the more leverage...
Patrick
Patrick
After a lot of research, I think I will go with the Zeiger Steering from EverettPerformance.com. I will be looking to do a Single Ram Full Hydraulic system. $2,620 complete including Helm.
Patrick
Patrick
Your Better Off With Two Rams Dosnt Put The Load On One side /////// wiil wear The gimbel Bushings From Pushing On One side Go With the Two Cyl ///// Pat I Like It Closer To The Gimbel Less Stress On The whole system ////
