Bilge size in a 24 Super (cuft)?
I don't have the boat at the house right now and was wondering if anyone knows the apx size of the bilg on the 24 Super i/o?
I'm adding a fire supression setup for peace of mind before next season (a friends boat burnt sitting on the trailer last summer). Also, figure its not a bad idea since we overnight onboard frequently and have more wrapped up in the motor.
From what I can remember, it was around 100cu ft or so??.. I'd like to stick with the smallest that will do the job to save weight (was planning on a fireboy 125, or 150cuft model)
If the bilge is about 7X 4X 3 that is less than 100 cu ft. You should be fine with a 125, and remember alot of the air space is taken up with a big chunk of steel. I know my Y2K is rated at less than 150 cu ft.
