Outrageous
Mike, If you have an interest in "Night Moves", contact Paul with a
reasonable offer and it will be yours. I need to move it along to get
smaller boat for the lake. Thanks, George
Hi dba, The boat needs complete engines including raw water pumps,
exhaust manifolds & risers. The B/W trannys w/couplers, engine plates,
TRS drives w/Mirage props, Kiekhaefer (large) k-planes, lift pistons and
pumps both trim & tilt are all there incl the p/s pump & bracket. One of
pistons will need a reseal and clean up connections on the trim tab motors
from sitting. Go onto Boat Trader under Sutphen and you will see all the
photos listed. Thanks, George
Does Night Moves have a longer deck and shortened cockpit?
Phil, I measured the deck once before quite a while ago and if my memory
is right from the front edge of the cowl to the tip of the bow is either 20' or
22'. I can go to Port Edgewood on Sunday and get an exact reading for you
if you want me to. Let me know and I'll take the ride for you. It is most
definitely an original flatdeck with the hand rail down the center. Thanks,
George
George
George,
No need to measure it for me. I thought from looking at the photos of it in it's present state, that this boat would make a great outboard hull as well.
