A few stir-the-pot questions
#31
I just purchased a pair of labbed Hydromotive 29 pitch P5X through the classifieds. I will be very interested to see how these work. 32" B1's were definitely not the prop for my boat. I hit a wall around 4000 rpm that I had to nurse the boat through. I am guessing that the small M1 prochargers were not making enough boost at that point. It was also taking a little longer to get on plane with the Konrad drives. I'm looking forward to trying these out. I'm not so interested in top speed.
#32
I think the rule of thumb is 500 hp on TRS drives.
I chased an RF signal for a whole season on my drag car. drove us freakin nuts. I had just changed the cam and was sure that was the cause. Changed back same problem, So we checked valave adjustment, fuel prump out put. all kinds of things , I even called MSD and sent them my box. They sent it back said it was fine.
eventually I got the RIGHT guy on the phone at MSD and he said that RPM is where Rf kicks in. Re wired and shielded Problem solved.
#33
I am not sure what ignition your using but that 4000 RPM number is kind of a majic number for RF signal problems to show up with MSD ignitions.
#34
yep check the way your wires are running , if they run parallel to eachother anywhere you probably have an RF signal problem. they need to cross at 90 degrees or separated from eachother.
#35
#36
yeah not much testing going on in maryland at this point in the year. same here in Ct. Sucks wehn you have an unresolved issue.
That boat is gonna thunder when its done. Its one hell of a nice boat.
#38
ours originally had 330's I think and ran mid 70's when my buddy owned it, If Memory serves me right but that was almost 20 years ago so I am not sure.
Plus there was only the dream O meter back then no GPS so who really knows.LOL
