Another Sutphen born again
#62
Registered User
Nice job on the boat looks very sharp!!!
Im also building a 31 and have a question about exhaust height from the water,how far is the exhaust from the water when it's sitting still??
If you could give me a call i would appreciate it
my #781 389 8055
thanks bill
p.s... I tryed to buy that boat and you beat me too it!!
my #781 389 8055
thanks bill
#63
Social Distortion
Took her out yesterday with an external fuel pressure guage. Think it's the fuel regulator. Going to replace it this morning and take her out again to check. Suck it t-boner.
![Bunnydance](/forums/images/smilies/bunnydance.gif)
#67
Social Distortion
Well, replaced the fuel regulator today in the cool fuel system and, although it helped, it didn't solve the problem. We are pretty sure that there is a kink or crack in the fuel line leading from tank to pump. We were getting 35 lbs of pressure but when we pinched the vacuum hose we got the 43 lbs that is normal for these engines. I'm just going to replace every line and fitting from tank to seperator, to pump. If that doesn't work, I'm stumped. I did idle much better with the new regulator though so it wasn't for nothing.
#69
Social Distortion
They are '99 models but either way I replaced the pumps already. I will keep you guys informed after I replace all of the lines and fittings from tank to pump. It only takes one crack or kink to jack up the fuel delivery.
#70
just read the whole tread and what a nice job! I also have a place at home to store toys, with a ''soft floor'' like yours where you painted the boat! I'm really impressed with the quality on pictures at least, of the paint, when you know where it was done... makes me think I could do it at home also !
Really, no flies or mosquitos or whatever in the paint? no dust?
Nice resto!!! don't give up the hard work, just a little problem to solve is quite simple from where you started !!!
