potential 390 project...need input from the community
What do these weigh?
Sick Stinger just parted that out last year.
IMO, if you can't swing # 6's for it, roll on by.
After the trouble of all the transom work I'd guess you'll eat Bravos up with that, even XR's
Unless you lollygag around at 2000 RPM all the time.
So there's that headache.
^^^^ this
if you don’t want it I might be interested.
I would have picked it up from Sick but didn’t have time to make the trip north at the time.
I'm not buying that just yet.
Maybe that's with no power or drives.
Hopefully some knowledgeable Sutphen guys chime in.
The owner used to be on here.
Think it said 1000HP a side and he was at 107MPH.
Well what do ya know, that unrigged Facebroke ad had this photo of a brochure. Courtesy of that guy.
Claimed 8550 dry with 500's and Bravos.
I was guessing heavier than that.
Bravos regardless. Good luck.
since this was orignally rigged with 6's, it would be heavier for sure.
Hoodoo 2.0 its all yours if you want it. not wanting to spend #6 money on a 'could run good, if i throw 80K at it'
What are they asking for it ? does anything else come with it
its honestly too good of a deal to be true, IF the hull and stringers are all fine. he's asking 10800, WITH the trailer it sits on. partially rigged, just needing drives and power.
possibility for transom to be bad, BUT if youre going to pay to convert it to bravos that has to be done regardless. i figure depending on weight and power, with maybe 600hp per side and bravos it could be a low 80's boat, prob upper 70's tho if its 9000lbs.
I figure that trailer has to be worth 6K easy.
30-35K drives
12-16K transom assemblies
35-40K engines
5-7K trannies
8-10K exhaust
10K misc
Buy Moses TG turn key, add gas and go.......lol
35-40K engines
5-7K trannies
8-10K exhaust
10K misc
Tiki Joe (07-19-2023)
the build sounded way more fun before I had all the expenses in plaintext in front of me
