Pair of Marine Machine Wingplates
I got a used pair of Marine Machine wing plates.
One of the bosses was broke when I removed them but it acts as a spacer anyway, I still have it (you can see it in the second picture) and can have it welded back on if someone really wants it, but you doing it will keep the cost down. It has angled holes in the top to accomodate a dual pick-up style drive shower.
These cost $825.00 / each new.
I'll take $600.00 for the pair - plus shipping.
Mark
Mark
reduced price to $600..... for the PAIR! There is a pair in the classifieds and they want $600 EACH!! this is a deal!
Honestly, I'm embarassed to say I dont know what a #4 drive is exactly, but I am sure someone on here could answer that.
If the hole pattern is the the same to the transom assembley then I would say yes. But I dont know if the hole pattern is the same.... someone will probably chime in with an answer....
Mark, I am quite sure they will not fit a SSM4 bolt pattern. I will take them. You should have my phone number in the previous PM I sent you so I may get your address....and in turn I will send you a check, so that you may send them out. Give me a call tomorrow AM or whenever you get a chance. Thanx, Mark
The name of the bank is called Macatawa Bank. It is a local bank here in west Michigan. I gave them $500 cash for one of their cashier's checks made out to you......so, there shouldn't be a problem, but if there IS a problem, then please advise me. Thanx, Mark
