454 Short Block Fresh from Machine Shop
Gen V .060 454 4 bolt main block,block was decked,and align honed,has new cam bearings,brass freeze plugs,L2377F-.060 pistons,Chevy 7/16 Dimple Rods,steel crankshaft,all new bearings,rings,complete assembly was balanced, balancer and flywheel to go with it. just needs to be assembled.
Also going with it are a set of Oval port cast heads Casting number is 10052902, 2 cams one used crane cam, Crane Cams 132561 SC cam Hydraulic Flat Tappet, Advertised Duration 298/306, Lift .530/.551
One new Comp Cams 11-236-4.
Also have the oil pan and windage and more misc. parts to go with it
Will ship if necessary, figure the block will go on a pallet and the rest of the parts in 3 or 4 boxes separate or tied down to the same pallet.
Asking $2700 and that includes the ride as long as it in the continental U.S.
$2500 if you pick up.
Being transferred to another state for work, boat this was going to go in is all-ready sold and this is whats left, have no place to work on it where I'll be.
