(2) COMPLETE 525efi systems - LIKE NEW!!!
Folks... these are 2 of the most complete 525efi systems that I have ever seen. I was going to use them in a custom 540ci 525efi build but am changing direction in power. Everything pictured is bone stock and VERY clean... almost unused. I have a scanner and will try to "safely" jump start the computer this weekend to obtain the hours... cant imagine there would be much on the register.
I will do my best to get the hours out of the computer... if you guys know which two pins to energize (positive and negative) on the main harness then let me know and I will post the hours asap.
$3,750 per kit. I do take paypal if needed but would rather have cash.
Thanks for looking.
- 525 Intake with injectors and factory air filter
- Cool Fuel system with twin filters and block aux pump
- Main computer with mounting brackets and harness
- Sensors, hardware, brackets, and misc bolts for installation
- Factory Spark Plug wires
- Distributorless ignition system with Distributor style signal unit and CDI bank
- Misc coolant hoses and hose brackets
Thanks for looking.
Thank you for the offer. I would rather just keep everything intact and sell complete. You could just buy the kit then split it up on your side of the fence? Always an option.
Thank you
Thank you
