SX Performance 1000 HP Fuel Pump
Perfect working condition, removed from Eliminator Daytona. $200 each.
EFI & Carbureted In-Line Electric Fuel Pump
Supports carbureted engines up to 1300 HP and fuel injected engines up to 1000 HP at 45 PSI
Ultra high-flow rates exceed: 80 GPH at 12 volts and 45 PSI, AND 120 GPH at 12 volts and 10 PSI
Flow-thru design maintains maximum cooling, produces outstanding reliability, and provides consistent fuel delivery from idle to full throttle
-10 AN inlet/outlet fittings for easy installation
Can be mounted inside fuel cell or external
For use with gasoline or alcohol fuel systems
For race or marine use only
Not for use with reduced sulfur content diesel fuel
Refurbish program now available for this pump
Passes UL standards for Coast Guard approval for use in marine applications
AUTOCONNECTIONLLC.COM
