SSM #4 drives and Gimbals/transom assemblies
I still have the IV`s . One is at collabellas getting new gears.. $10k for drives/spacers only . I do know of some transom assemblies if needed. Props are gone.
Edit:
RH drive will have new upper (straight cut forged) and lower gears.
Transom assemblies :
These are available (painted purple) $3500 fresh water since new:
Fresh Huber 1200 plug in with cryptonite shaft also available
Edit:
Drives are 1.48 ratio.
As the description says :
Not sure on the upper ratio but I can ask. lower is 1.25
LH has 26 spline big shaft RH has a 19 spline new shaft ( I use the 26 spline Arneson adapter)
Sent
