Mdercruiser 454 BLOCK 4 bolt standard bore excelent cond.
454 Block 4 Bolt main "K" code
, with caps harmonic balancer, flywheel, crank (it's cast and may be turned) never bored, clean cylinders no rust, taper or ridges, was rebuilt 50 hours ago (flaked #1 rod bearing) $450
Pan w/dipstick $100
731 spec'ed Cam $100 (Cam Motion) $100
Melling Oil pump with tube $50
Cloydes timing chain and sprocket $50
Pan w/dipstick $100
I am located around the Paducah, KY area. I will check on the shipping charges on Monday and get back to you. I was hoping to get close to $450 for the block and caps.
I just read the bare block w/caps weight is about 225#. I think my shipping guy can get a good price on it palatized and wrapped, I will know for sure Monday what that number is.
