Huber 1050 plug in #6 trans
Huber 1050 plug in trans. Bought it for my boat and ended up going bigger. Has #6 tailstock in excellent condition. 2500 without tailstock 3200 with tailstock. Also have trs tailstock availiable. Call or text 781-733-6595. Will ship at buyers expense.
-Dan
-Dan
Bump** 3,000 with tail stock. Shift cable mount not availiable.
Its a huber hm 1050. I believe they rate them off torque? So 1050 ftlbs. Hopefully someone will chime in and confirm this. Any performance marine trans shop can also make them into 1350 or 1550 power ratings aswell.
I believe they have more then 3 but each model number , 1050, 1200,1450,1550. Huber rates them off engine torque not horsepower from ive gathered off there website they have a graph. Once you get to there 1550 its a “dry sump” which is what i currently have in the boat. The dry sump is literally just a deeper oil pan and baffle to keep the oil further away hence less resistance. Unlike a dry sump in a engine. The bigger the torque the more clutches they add to the forward gear.. any of them can be modified bigger or smaller i believe
