Post Migration Tech Reporting
Never Enuff
Sign on is extremely slow. Had to try two or three time before the connection was made. Also very slow when trying to move from thread to thread.![Mad](/forums/images/smilies/mad.gif)
Jay
Jay
OffShoreOnly Tech Crew
Thank you guys for the feedback.
Westcoast, are you aware of anyone else having this problem? What time of day does this usually happen (if all the time, please give us a general idea of when you're on the site)?
never enuff, the problems that you're describing can be tricky. We'll do our best to diagnose quickly, but it's likely to take a few days just to come to a conclusion about what the problem is, and from there the fix may take anywhere from a few minutes to another few days to implement.
I'll try to keep you all in the loop as we go through the process of figuring out these issues.
Hello , thanks for your hard work , its realy appreciated !!, i realy like this place , when i try to made search for two word , i always have this message
Fatal error: Allowed memory size of 33554432 bytes exhausted (tried to allocate 71 bytes) in /var/www/www.offshoreonly.com/forums/search.php on line 1028
Thanks again ...and long live to OSO
![Drink](/forums/images/smilies/drink.gif)
OSO Content Provider
![](https://www.offshoreonly.com/forums/images/icons/commercial_member_star.gif)
![Post](/forums/images/icons/icon1.gif)
I noticed an issue in the Racer's Forums.
The header is lower than normal.
Apparently a code that is in place may be the problem ?
<br />
<b>Warning</b>: Call-time pass-by-reference has been deprecated; If you would like to pass it by reference, modify the declaration of convert_bits_to_array(). If you would like to enable call-time pass-by-reference, you can set allow_call_time_pass_reference to true in your INI file. in <b>/var/www/www.offshoreonly.com/forums/forumdisplay.php(106) : eval()'d code</b> on line <b>62</b><br />
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html dir="ltr" lang="en">
Yesterday the site felt like I was on dial up.. Maybe just the transition to the new servers?![Confused](/forums/images/smilies/confused.gif)
Better today though.
<br />
lucky strike
04-19-2004 01:03 PM
Peconic
General Racing Discussion
19
08-12-2003 02:32 PM
