The B.S. Thread >
The B.S. Thread
The B.S. Thread
Old 03-18-2009, 04:49 PM
  #27661
did you make this post to let everyone know you where up at 6:00AM??
Do they make anything that can be intalled between the header and the tail pipe?
jeff1000man is offline
Old 03-18-2009, 04:56 PM
  #27662
tomtbone1993's Avatar
Originally Posted by mba1620
I bought these whenever I blew mine out. No welding and took me about five minutes to install.
http://www.danamarineproducts.com/ExhaustFlappers.htm
Interesting....those look better than the other ones I posted. Thanks
tomtbone1993 is offline
Old 03-18-2009, 04:58 PM
  #27663
Not that I have found. I bet the ones MBA posted would work hooking them up to the tails
Old 03-18-2009, 05:02 PM
  #27664
Don't you have a big rubber hose that connects the pipes to the tails? Could you install a flapped inside there between the pipe and the tail? Then it would be easier to service.
Old 03-18-2009, 05:16 PM
  #27665
That is what I was thinkin. The ones MBA posted should go up the tail before it goes in the rubber hose. The ones I posted would be an issue in the rubber hose. I am worried they would stick or not even work.
Old 03-18-2009, 05:36 PM
  #27666
Or maybe have them welded into the end of the tail pipe so that it is still inside steel, but it is easier to service since you can remove it from the rubber hose that joins the two. I am not sure if it wouldn't get stuck if it was in the rubber hose when it got hot and expanded or cooled and then got stuck.
Old 03-18-2009, 05:43 PM
  #27667
I am concerned about the 45 degree angle w/ the rubber hose. There is only a few inches seperating the tail from the tip.
Old 03-18-2009, 05:44 PM
  #27668
That is why I was thinking you could install it into the tail pipe, so that it isn't effected by the rubber hose.
Old 03-18-2009, 05:45 PM
  #27669
In other news, SSCC is up over 33% today. Did they fire Joew?
Old 03-18-2009, 05:47 PM
  #27670
His last day is Friday
Quick Reply: The B.S. Thread
