The B.S. Thread
it was on repeat on the houthboat yesterday, i was irritated none of the girls knew the movie and wanted to change it, then i realized this morning it is 12 years older than the oldest girls on the boat!!!!!!!! Yaaaayyyyyy ![Evil](/forums/images/smilies/evilB.gif)
![Grinser010](/forums/images/smilies/grinser010.gif)
![Lolhit](/forums/images/smilies/more/lolhit.gif)
1. Royal Flush
This is the highest poker hand. It consists of ace, king, queen, jack, ten, all in the same suit. As all suits are equal, all royal flushes are equal.
2. Straight Flush
Five cards of the same suit in sequence - such as J-10-9-8-7. Between two straight flushes, the one containing the higher top card is higher. An ace can be counted as low, so 5-4-3-2-A is a straight flush, but its top card is the five, not the ace, so it is the lowest type of straight flush. The cards cannot "turn the corner": 4-3-2-A-K is not valid.
3. Four of a kind
Four cards of the same rank - such as four queens. The fifth card can be anything. This combination is sometimes known as "quads", and in some parts of Europe it is called a "poker", though this term for it is unknown in English. Between two fours of a kind, the one with the higher set of four cards is higher - so 3-3-3-3-A is beaten by 4-4-4-4-2. It can't happen in standard poker, but if in some other game you need to compare two fours of a kind where the sets of four cards are of the same rank, then the one with the higher fifth card is better.
4. Full House
This consists of three cards of one rank and two cards of another rank - for example three sevens and two tens (colloquially known as "sevens full" or more specifically "sevens on tens"). When comparing full houses, the rank of the three cards determines which is higher. For example 9-9-9-4-4 beats 8-8-8-A-A. If the threes of a kind were equal, the rank of the pairs would decide.
5. Flush
Five cards of the same suit. When comparing two flushes, the highest card determines which is higher. If the highest cards are equal then the second highest card is compared; if those are equal too, then the third highest card, and so on. For example K-J-9-3-2 beats K-J-7-6-5 because the nine beats the seven.
6. Straight
Five cards of mixed suits in sequence - for example Q-J-10-9-8. When comparing two sequences, the one with the higher ranking top card is better. Ace can count high or low in a straight, but not both at once, so A-K-Q-J-10 and 5-4-3-2-A are valid straights, but 2-A-K-Q-J is not. 5-4-3-2-A is the lowest kind of straight, the top card being the five.
2. Straight Flush
3. Four of a kind
4. Full House
5. Flush
6. Straight
Hey guys, had a blast at your poker run. Tbone, thanks for introducing me to some of the OSO guys, glad to meet all y'all. Someone pumped some serious money in to Del Lago. That place was awesome! Hope there wasn't a full house cause that beats a flush guys. Tommy
