The B.S. Thread
#9321
Just got back from running all 3 stops. Only used 3 quarts of oil this time. Apparently all that GOOP on the front of the enigine is starting to hold back the floodwaters. I am putting some more on tomorrow.
Stops are
1. My dads boat dock on the north side of the bridge. Everyone that has been there knows that it is safe. ( water is no less than 5' under the keel and I just backed the drives over all of the hydrilla so it is safe) I will make a map for those of you who don't know where it is.
2. Del lago. Boatman22's buddy will work that stop. He is in charge of the marina right now while no one wants to use it. You just have to go by the dock like olds times, go past the pump and make a u-turn. I was within 5' of the bank on the way out and the depth guage never read under 4'
3. Bella Vida. Don't know who is going to work that????? - Lefty- can you get the se.xcretary to go out there. Everything was fine during the TOPPS run, so I don't know why it wouldn't be now.
Stops are
#9322
Im in for 200.00 weather its for 1 hand 2 hands or 4 hands.
Im also for it being a 7 card pull.
I think we should still play hold em, but not part of the PR.
like i said before if we do a 50.00 buy in we have more hands and better odds.If all the people that commited to 200.00 then they will have no problem buying 4 hands.
The only negative is that now a cheapazz that is going to only buy the $50 now technically has the same chance to pull a winning hand as you do. If you remember from 5th grade, the law of probability still stays the same because everyone is reaching into the same bucket, and it is a bigger pain in the azz.
I will make a decision on the hands tonight and get back to ya'll.
We will play Tom's way though and reach into a single deck bucket and return the cards and shake it up after each pull.
I see that being a much smaller pain in the azz.
#9323
Technically the odds stay the same. If everyone was planning on $200 and I divide it to 50. everyone that was going to play, still plays, they just get 4 chances to make a good hand. But, so do you.
#9324
OK everybody wants an extra chance so I came up with this.
What about a free hand. We will give out chips at the stops #'d from 1-300, or however high we need to cover the hands. under 100 hands. 300 chips is sufficients. I am betting we have less than 50 hands, so I will start with 150.
Each hand pulls a chip at each stop. when you show up to pull your cards, you put your chips into the pot.
Each hand should have 3 chips. We will audit this to coincide with your recipt card.
After all hands have been pulled and posted, we will draw the winning chip out of the pot and that person gets to pull a new hand. You can have a designated puller if you don't feel lucky.
#9326
Not trying to be a Di(k of all the different type of runs I have done, This was the easiest and the funest.
At $50.00 a hand I will still buy $200.00 worth. But I have no intentions on buying anymore. I can also tell you my passengers will buy hands as well for $50.00
