Can a F350 SRW PSD SAFLEY tow a Cafe or TG?
Re: Can a F350 SRW PSD SAFLEY tow a Cafe or TG?
Originally Posted by birdog
You know, Rus.................
You CAN lower the air pressure when empty !
Especially when I keep an air hose nozzle and air guage in the map pocket.....
I run 70 psi. I keep taking tools/materials off/on so much I'd constantly be changing air pressure.......
Member #154
Thanks Trout You're correct about the rotors, I have the '99.0 and mine are warped and cause a noticable vibration when braking hard. That'll be a nice $$ to correct
Troutly: Are you aware of a tire manufacturer making an E rated tire in 285/75/16? The 285 Revo's I'm running now are great tires, but only offered in D.
Forum Regulator
Chart,
BFGoodrich All Terrain KO
Performance Boat Center
Originally Posted by Sydwayz
Chart,
I got Ds because the tire guys said that they didn't actually make them in an E.
285/75-16
Tim Gallagher
Performance Boat Center-FL
[email protected]
954-809-8739
Wright Performance, MTI, Cigarette, Sunsation
Tim Gallagher
[email protected]
954-809-8739
Interesting on hitches, my class IV Draw Tight is rated for 12,000 lbs not distributing and 14,000 distributing. The reese IV hitch says 7,500 GW and 12,000 distributing. Another one I looked at says 10,000 GW and 12,000 distributing.
I figured it was a standard number?? Learned something new today. Sorry to lead you astray, I would say change your hitch to at least 12,000 GW non distributing and 14,000 would be better.
Forum Regulator
DAMNIT!
Tim Gallagher
[email protected]
954-809-8739
Tim Gallagher
[email protected]
954-809-8739
Toxic FORMULA
Nitto Terra Grappler 305/70-16 Load range E. Dynomite tire , good traction wet or dry , good iin snow , and reletively quiet on the highway.
