O.T. Dodge truck, o.d. unlocks to low rpm.
I have a 97 dodge 1500 with a 5.9L and an automatic tranny. The problem is that the o.d. is staying on at to low of rpms, check engine light comes on. Now it is kicking the o.d. off from getting hot. I have changed the fluid and the output speed sensor. nothing helps and problem is getting worse.
Anyone with any knowledge of this problem? I know I dont.
Re: O.T. Dodge truck, o.d. unlocks to low rpm.
Ours is a 98 1500 with 5.2. Output shaft sensor went out towing the fish boat to Arkansas and exhibited similar probs. Had a bad shudder in OD running Dexron III after a trans flush at 50k. Make sure you use the Dodge fluid or equivalent. Flushed again with the Valvoline equivalent to the Dodge fluid at 60k. No probs til 127k miles. Trans started holding first gear longer and slipping going to second. Drove it like that another thousand miles and took to a good trans shop before it left us on the side of the road. 1600 dollars later I have a rebuilt tranny and converter warranted for 70k miles. I could have opted for the 1200 dollar rebuild warranted for 12k but chose to spend extra for what basicly is the same trans with an extended warranty. In order to qualify for the extended warranty I had to run an aftermarket trans cooler and bypass the factory cooler. Also there is a check valve inline on the lower factory cooler line. It was cut out and replaced by a magnetic inline filter. Apparently the factory coolers and check valve will fail and hurt trans badly. There is also an input sensor so go to Autozone and get them to pull the code(ITS FREE) to make sure its nothing horrible . I hope yours is the sensor.
21 and 42 footers
My Dad had a 98 1500 with the 5.9. Sold it with 52K miles and never had a problem. Only towed a bassboat with it. 2 weeks later I find out the tranny went on the new owner. After asking around I kept hearing Dodge had alot of problems with the trannies in those trucks. That isn't much info, but all I know about them...Good Luck with it.
