Upgrading the hitch on my F-250
I'd like to upgrade to a true Class 5 hitch on my F-250, something that will do 10K+, weight carrying. One caveat - I already have a 2 in x 2 in, 12K solid steel shank with a 10K ball. I'd much prefer to be able to continue to use this item, as it cost me a pretty penny and I've only used it twice. As I understand it, the Reese Titan is a 2.5 inch receiver, so my shank would not work with it, correct? Or is there an insert or sleeve that could do the job?
Thanks!
Thanks!
Forum Regulator
You can obtain an insert for the Titan.
Another solution:
http://www.putnamhitch.com/Trailer%2...%20Hitches.htm
(looks like their Ford page is down, might have to call them)
Another solution:
Call Weaver Distributing and get the Putnam XDR Class V. Great prices and free shipping east of the Mississippi. 800-932-8373
If you have the lame class 3 reciever (like my F250), can't you use a "Weight Distributing" hitch with it to get to 10K?
That's what I was thinking of doing since the WD hitch cost about the same as a new reciever.
Thoughts any one.
Uncle Ernie.
Thoughts any one.
![Roll Eyes (Sarcastic)](/forums/images/smilies/rolleyes.gif)
Uncle Ernie.
Originally Posted by Bob Zubik
Just did the same thing on my F-350 chose the curt 12k model love it check out the Curt stuff b/4 you buy....BZ
Forum Regulator
I went to a WD hitch first on my factory (GM) Class-III hitch. Pages 1 & 2 of this post have a lot of information:
http://www.offshoreonly.com/forums/s...vy+hitch+balls
Its NOT a lot of work to adapt to your trailer, and WELL worth it.
I have now upgraded to a Putnam XDR Class-V hitch. (Engineer by trade, decided to overkill it.) It bolted on in a few minutes. I still use my WD hitch setup at almost all times. I was only moving the boat 8 miles yesterday, and did not hook up the WD bars. I will next time for an 8 mile trip. Its worth it. The whole setup tows much better. (12K lbs.)
I guess I should double check
. I got the towing package also (w/6.0L Diesel) but saw that the 2" reciever and figured it to be a class III.
BillR
2
10-24-2007 08:36 AM
