GM recall
#41
A to Z
Re: GM recall
Originally Posted by pull my trigger
AND NIETHER WAS THAT.........azzhole
and dont start your standard backpeddling routine by saying it was just a joke because thats all it is.....a routine
if you don't like him, ignore him......
#42
Re: GM recall
Originally Posted by Sean H
actually they are bmw derived v-8's, you are a few years behind on the buick stuff... they are running the engines from when BMW took over for a few years, and the new ones (06) are sweet..... and yes the new ones are ford motored (land rovers)....
#43
Re: GM recall
Originally Posted by mikes280
range rover has a old buick v8 from the sixtys in it so what asbout a ford
what is wrong with you people, it started out to be a ford chevy thing.. a joke.. pull my trigger i dont think i own the site, because i said do you know who i am.. do you know who i am, if you would take that comment serious, you must be a putz, so i take back all my jokes... dont be a putz...
you guys take sh it way too serious.. this was my thread, your the one who added your thoughts... you should change your name to pull my pud..... stecz
#44
Re: GM recall
Originally Posted by stecz20
land rover is owned by ford.....
#45
A to Z
Re: GM recall
when did they stop using the old 215 i know it was in them just a few years age because i have worked on them i am not sure on the newer one we stopped working on them because the elect. was always a mess got tired of trying to fix all the shorts and comp problems
#46
Re: GM recall
Originally Posted by Sydwayz
Wannabe,
What is the fix action, do you know? I have upgraded my brakes a bit.
Thanks!
Thanks!
The salt is causiung corrosion on the surfaces the abs sensor reads from and the systems detect slippage when none is present.
Wannabe
#47
Re: GM recall
i was just saying that they used to run a gm motor thats all nothing else YOU take the way you want
this pissing match has nothing to do with you, your one of the good guys.. i was just giving you my information....lol yes and sean h is correct, for once...
#48
A to Z
Re: GM recall
#49
Re: GM recall
i am just honored that you even mentioned my name....
It is mentioned alot....
Sean h is a pud whacker
Sean h better bring 190 to LOTO next year
Sean h will get spent by Byrdman
#50
speel chekk this fokker!
1 Post
Re: GM recall
and for those of you interetse din et recall. They wont; officially release anythign on it until probably january. I calle dyesterday becasue my truck is doign EXACTLY what is described.
Pardon me, while I whip this out!
