Gear Ratio - Chevy????
Forum Regulator
Re: Gear Ratio - Chevy????
GT4 is 3.73
GT5 is 4.10
GT5 is 4.10
Originally Posted by bouyhunter
OK - I haven't ventured out to start checking the truck yet, but , how difficult would it be to cange out the gears to allow me to tow the higher weight??
would it be best to just replace the entire axle?
Buoyhunter:
If your truck has a GVW of 7200 lbs you probably have the HD rear axle. The Differential will look different, wont' have the 2 notches the std. Gm axles do on the bottom at 5 and 7 o'clock.m This is a much stronger axle than the regular half ton axle.
The tranny is your other weak link- trailer only in Drive , NOT OverDrive ON THIS MODEL.
You have plenty of power with the 350 Vortec.
Wannabe
Wannabe
Oh praise the board!!!!
Thanks guy's - I should have it figured out tommorow morning. No tags, any more hint's on that glove box code???
The 3.73 is what I was hoping for - allows me 7500#'s - maybe I can still look at the Cig Bullet's.
Thanks. Bouy
Thanks. Bouy
Front Side of the axel tube on tha passenger side is a series of numbers stamped into the housing that will tell you the gear ratio. You may have to "wire wheel" the area to see it as it usually gets covered up with grease & dirt, but it is there.... Ill try to find the link that will tell you & post it. Is for GM vehicles only.
This site will decifer all the GM "Spid Codes" located on the glove box door, & or the trunk lid of most cars> http://www.fl-thirdgen.org/rpo/rpo.html
This may work to decode the VIN of GM Truck, I know it works for cars for certain years. Tells you where it was built, etc....> www.nytmare.org/fiero/vin/decoder.htm
Originally Posted by birdog
A Bullet is #8900 Dry, No trailer....Trust me...1/2 ton aint gonna get it around here. Sorry......
acccording to the sticker, the rear-end is a GU6 G80.
3.42 / limited slip posi.
OK - that puts me at 6500#'s
Gofastboater - thanks for the link, that helped alot.
Smitty, $750 would probably be worth it, thanks for the info and advice
Originally Posted by wannabe
Buoyhunter:
Wannabe
Wannabe
I posted a picture zoomed in on a broken gov-lock drive gear,it is real common problem even in the hd trucks.
