electric/hydraulic brakes
Old 10-25-2005, 07:00 AM
CAVelocity's Avatar
Default Re: electric/hydraulic brakes
I have the Carlisle unit and they have a module that allows the Prodigy and the integrated Ford controllers to work. Works great.
CAVelocity is offline
Old 10-25-2005, 08:01 AM
wrinkleface's Avatar
Originally Posted by plumbers crack
Got the new boat and truck but the trailer has a delay when applying brakes.Brake controller turned all the way up to 10.The trailer should be able to stop the truck somewhat.System is definately working,can you adjust brakes to be more responsive?Brakes on all three axles 11,500 lb boat.Disc Kodiac 250 calipers.
There are 2 dif. adjustments on my brake controller. I believe one is for how fast(delay) you want the brakes to grab and the other for how hard you want them to grab. Have a Draw Tite activater2 and a Carlisle system on the trailer. Good luck Wrink
wrinkleface is offline
Old 10-25-2005, 04:54 PM
plumbers crack's Avatar
Thumbs up Re: electric/hydraulic brakes
The only problem is I cant tell what kind of brake system is on the trailer.The trailer is a vanguard vip arizona.Also noticed a switch on the truck controller(reese)on side for sync?I will do a search on the trailer co.Anyway to tell stickers are painted Doent look like a brake rite mine is long rectangular.
plumbers crack is offline
Old 10-26-2005, 07:15 PM
Cool Re: electric/hydraulic brakes
I read the instructions today the sync switch makes the brakes come in faster so we will see how that works first.I forgot about it even though I saw it when installing it!
Old 10-26-2005, 08:17 PM
RedDog382's Avatar
Brake rite unit:
Attached Thumbnails electric/hydraulic brakes-57-motor-003.jpg   electric/hydraulic brakes-57-motor-004.jpg   electric/hydraulic brakes-57-motor-002.jpg
RedDog382 is offline
MarkDonzi
5
02-10-2007 09:00 AM
berns29scarab
10-30-2006 01:03 PM
gferdon
4
05-11-2006 08:17 AM
lonestar382
4
08-19-2004 08:19 AM
Skip
7
12-16-2002 07:43 PM
Quick Reply: electric/hydraulic brakes
