What Tires will fit a 2003 3500 Dually ? Need Bigger >
Old 12-17-2005, 08:42 AM
Viper31's Avatar
Default Re: What Tires will fit a 2003 3500 Dually ? Need Bigger
Rob,
Did you ever figure out what size tires worked best for your dually?
Viper31 is offline
Old 12-19-2005, 11:15 PM
Rob
Strip Poker 388's Avatar
It looks like 235-245 with out spaces and with the spacers up to 285. I haven't done anything yet. I cant decide what to do and i have about 10k left on the front tires.I think any thing bigger that the 236 I will need to recalibrate the speed-do .if the idiots here know how
The truck just looks funny with such small tires
Rob
Attached Thumbnails What Tires will fit a 2003 3500 Dually ? Need Bigger-truck-11-small-.jpg   What Tires will fit a 2003 3500 Dually ? Need Bigger-engine-install-4-17-05-026-large-.jpg
Strip Poker 388 is offline
Old 12-20-2005, 05:41 PM
Viper31's Avatar
Rob
Agree. Although I think 235/85's might touch on the inside on the rear. I measured my truck and there is only one inch between the stock rear tires. Dunlop's website shows the following measurements:
215/85/16 Stock Tire
Section Width = 8.6 inches
235/85/16
Section Width = 9.3 inches
My truck also has rubber valve stems instead of steel. What dumb@ss bean counter made that decision. Thats just another upgrade we have to make in order to go to load range E tires at 80 psi.
Keep us updated on your project. There will be others of us who will be doing the same mods.
Viper31 is offline
Old 12-21-2005, 11:33 PM
A to Z
Sean H's Avatar
Originally Posted by Jesse James
I love this one I wish some one could tell me what has been done....lift, and wheel size etc.
22.5's with a 4 or 6 inch lift is usually what does it....
Sean H is offline
Old 12-22-2005, 08:42 AM
44MTI's Avatar
I run the 235/85/16, michelins. I realy like the way they look. They fill out the wheel wells alot nicer and just look like the truck should have came with them.Truck also seems taller when I'm driving, maybe it's just me. No problems with rubbing and tows great.
44MTI is offline
docmanrich37
12
12-17-2006 06:45 PM
KN
4
04-18-2006 10:19 AM
dukenrock
0
03-04-2006 06:29 AM
Quick Reply: What Tires will fit a 2003 3500 Dually ? Need Bigger
