Who uses Weight Distribution Hitch Setup?
I have a idea.....why don't you guys buy the correct trucks next time around.....your always trying to buck the system
Forum Regulator
Originally Posted by Byrdman
I have a idea.....why don't you guys buy the correct trucks next time around.....your always trying to buck the system ![Big Grin](/forums/images/smilies/biggrin.gif)
miamioffshore... ALL THE INFO YOU NEED is in the threads that I linked above, but here it is again.
http://www.hitchfinder.com/trunnion_WD_hitch.htm
Seriously, pony up the $20 bucks to see the pics. Its worth it.
Originally Posted by Sydwayz
I had a correct truck. I had a correct hitch. I prefered towing with a WD setup. It rides that much better.
Thanks again
Forum Regulator
I mounted my PTA below the trailer tongue, as shown in the pics. With the way the surge brake controller configures the height of the trailer tongue, this made things line up perfectly for my application. I had to notch the flat plate that bolts the two I-beams together just slightly, to slide the tongue jack(s) back to allow enough room for the PTA to fit. By adding a second jack, it reduces trailer twist when on the stand. I don't have the measurements, as the boat is in winter storage, but the retailer should be able to get them for you.
As far as your tow home... go ahead and upgrade your hitch on your truck before you go. Get either the Putnam XDR or the Reese Titan-V (yes its 2.5"). These hitches do allow you to be legal as to raise the weight rating of the Weight Carrying capacity of your truck to that EQUAL to what the weight rating is when using a Weight Distribution setup.
Let me state that a different way...
Your factory hitch is rated for 7K WC and 12K WD.
Upgrade to the Putnam XDR hitch which is rated for 15K WC.
By bolting that to your truck, you now are OK to tow 12K as WC.
This is per a GM representative and Putnam, as another OSO member verified in one of the old threads.
I am pulling the boat out of storage next week, so I can measure anything you may need.
Thanks for your help, I definetly plan on upgrading the hitch. What brand weight distribution setup did you go with, I'm thinking maybe I'll go with the BlueOx as it's rated to 15k and claims to have some sway control ability despite having no extra sway control hookups, which as you know are impossible on a pole tongue adaptor setup as there's no where else to hook them up to.
Thanks again,
M
Thanks again,
M
Forum Regulator
I have the Reese Trunnion setup.
Originally Posted by hammer01
Be Careful With The Wd Hitches Because They Will Not Allow Surge Brakes To Activate If This Is Your Brake Set-up. My Boat Is 11k Dry And Aluminum Tri-axle Trailer And It Towed Perfect With My 2500 Hd Duramax And Now Am Towing It With 2500 Suburban. I Used The Class V Hitch And The 2 1/2 Inch Receiver. No Squat Or Other Problems.
http://www.equalizerhitch.com/produc...patibility.php
Boatman,
That works on your boat trailer? I would think those spring bars wouldn't be able to hookup due to the pole tongue? Please elaborate, as I looked at that hitch but didn't think it could be setup due to pole tongues and that particular setup not being able to do its thing with the use of a pole tongue adaptor?
Sorry For My Vague Comment, I Should Have Clarified That I Had A Past Wd Application That Was Not Universal For All Trailers And It "may" Not Allow The Surge Brakes To Work Properly. I Went From A Steel Heritage Trailer To A Aluminum Tri-axle. I Should Have Been More Clear, I Just Know That It Is Frustrating To Order A Part And It Not Work For Your Application Without Expensive/extensive Modification In Some Cases, Especially With All The New Custom Trailers Available Today.
Performance Boat Center
Miami-
You don't need to get into all this...
That 2500HD will have no trouble with the tounge weight.
The hitch is fine. Though uphrading to the XDR is certainly not a bad idea.
I have had 21,000 on the stock hitch on the 3500. Yes, believe it or not...21,000lbs.
Me.. I wouldn't waste time with the wd bars and adaptors, and chains....
The balanced boat won't have much tongue weight.
Send me an email or call me any time.
[email protected]
[email protected]
Tim Gallagher
Performance Boat Center-FL
[email protected]
954-809-8739
Wright Performance, MTI, Cigarette, Sunsation
Tim Gallagher
[email protected]
954-809-8739
