Who uses Weight Distribution Hitch Setup?
Originally Posted by miamioffshore
Boatman,
That works on your boat trailer? I would think those spring bars wouldn't be able to hookup due to the pole tongue? Please elaborate, as I looked at that hitch but didn't think it could be setup due to pole tongues and that particular setup not being able to do its thing with the use of a pole tongue adaptor?
http://www.equalizerhitch.com/produc...patibility.php
Originally Posted by boatman22
They have a bracket that bolts to pole tongue. It's a very easy setup and makes towing a dream. If you want picture let me know.
Originally Posted by Tim G.
Miami-
You don't need to get into all this...
That 2500HD will have no trouble with the tounge weight.
The hitch is fine. Though uphrading to the XDR is certainly not a bad idea.
I have had 21,000 on the stock hitch on the 3500. Yes, believe it or not...21,000lbs.
Me.. I wouldn't waste time with the wd bars and adaptors, and chains....
The balanced boat won't have much tongue weight.
Send me an email or call me any time.
[email protected]
[email protected]
Originally Posted by OldSchool
Ditto!!!!! My 2500 Duramax crewcab tows my Top Gun just fine. No air bags or wd bars needed
I know about pole tongue adaptors? But are you seeing Equalizer has a special adaptor that gives it some rails to ride on?
Really?!? I was in Josh's the other day, he has airbags, no WD and I didn't like the way it felt from the passenger seat, couldn't imagine driving 1500 miles like that.
![Roll Eyes (Sarcastic)](/forums/images/smilies/rolleyes.gif)
Forum Regulator
Originally Posted by Byrdman
Yea....how did that feel..
.....have fun with all the wd cover up I am going to get swung off the road prior to rear ending someone problems....go buy a 4500 or something.....quit trying to rig it!.....find a used kodiak for 10 g.....put a hauler bed on it.....any time you have to put this garbage on your trucks....your compensating for lack of truck.....I have not been in this section for awhile....no wonder. ![Big Grin](/forums/images/smilies/biggrin.gif)
"Ummmmm, OK?"
Fyi, I Was In Contact With Equalizer Hitches And They Do Not Reccomend Their System With Certain Brake Actuators For Surge Brakes. I Also Called The Actuator Company And They State That They Need Over 4 Inches Of Surge To Be Effective And More Like 6. They Were Pretty Strongly Against Using The W/d Application. I Believe Mine Was The Dico Model 20 Acuator Which Is One Of The More Common Ones Out There.
miamioffshore
2
02-20-2006 04:47 PM
4mulafastech
12
09-07-2005 10:35 PM
