Deisel ??
Driver-441
Racer
Deisel ??
I no deisel's dont start up well in the cold weather so is there anything to kind of help them out? Like the engine block heater?? But that wont help the glow plugs, right?
Re: Deisel ??
Re: Deisel ??
"I" before "E' except after after "C" and except in "Budweiser"
Alot of diesels have "block heaters" which one can plug in (AC) during the winter- most auto supply stores sell these. I worked for an ambulance service and they worked well!
Re: Deisel ??
There is magnetic oil pan heaters...junkie quick ...then there is the one where you pop out freeze plug and put it in there....good one....and there is one that you put in your heater line....like a little pump with heating element....some do not have the pump and rely on heat gravity circulation..these are not great and must be set up to make sure of gravity up flow or else you will boil the element.......then you can put whatever you use on a timer to go on at 4 am!
