2500 GMC Duramax pull Donzi 38 ZR, safe or not?
Performance Boat Center
The entire drive train on the 2500HD is the same as on a 3500 Dually....
It'll tow that load like a dream... You should have no worrys.
I have pulled twice that with a 3500... really.
I know a guy that pulls 18,500 with a 2500. He added air bags to the rear suspension, but that's it... His truck just turned over 140k. Never had an issue.
Remember, this is a GM we're talking about, not a Ford.
![Drink](/forums/images/smilies/drink.gif)
Tim Gallagher
Performance Boat Center-FL
[email protected]
954-809-8739
Wright Performance, MTI, Cigarette, Sunsation
Tim Gallagher
[email protected]
954-809-8739
and leave the power programmer on it, thats why you bought it, to optimize performance and towing.
Thanks guys, it sounds like I should be ok as long as my tires and brakes are up to the task.
Charter Mod
Originally Posted by Harper220
I'll at least have to switch it to the lowest power level due to the weight of the boat and exhaust temp issues. There's also a warning in the manual that states each level will be safe to tow up to a certain weight.
I have the exact same truck with the chip and I used to pull my Top Gun to loto all the time. I never even had to turn the chip down.
...What do you guys think?
Originally Posted by candyman35
Check to see what your hitch is rated at.
Putnam XDR here.
![Smilie](/forums/images/smilies/smile.gif)
I would ask the EGT question at the Diesel Place.
http://www.dieselplace.com/forum/index.php
Lots of good info there.
Dan
Dan
if your going to tow that type of load set the hypertech in the lowest setting there is.you will still get a decent little extra grunt when pulling. If you leave it up high and start to pull some hills your egts will get a crawling. if any type of mods are done I would reccomend getting an egt gauge and boost gauge installed in the truck. Not that hard to add and a couple hundred for the a pillar and gauges.
Charter Mod
Do you have a chip or the Hypertech power programmer? If you have the H-Tech programmer and had it on the highest level, how would you know if you're running too hot or not? I'm not quite sure how the programmer brings more power to a turbo diesel, but I keep hearing exhaust temps are of great concern when re-programming and towing.
I have both an exhaust temp and boost gauge. I have the Bully Dog programmer on mine. I'd go ahead and turn it down on yours if you don't have a gauge. Mine has been fine but I can watch it to make sure.
