Oil Bath Hubs
"Unregistered Gun"
I havent had the wheels off yet, but I need to add a little oil to my hubs. What kind of oil do I use and do I pull the wheel to get to a fill spot?
Registered User
At the likely risk of sounding like a smarta$$...
...you use hub oil.
Any truck stop, dealer or service garage.
Doesn't the bearing cover have a little rubber plug in the center?
...you use hub oil.
its just 80-90 gear oil there should be a center rubber plug
pull that off and there is a line for the level it is about a 1/4 of the way up. They dont require much oil.
I am refering to 10,000# HD dexters
80-90wt gear oil for use in Ky area if you are gonna run out to Arizona or any hot climate go with 180wt gear lube. Same thing little rubber plug in the middle they realy don't take much. iIf you over fill em it will come out when they get hot.
Mine have an allen screw @ the base area. I dont need to remove my wheels but I do jack up the trailer to drain the oil. Refill it with 80/90 until the sight glass is full then tap on the hub to expell any air ,top it off & re install the plug . Also paint a bit of touch up paint to seal the plug.
Registered User
Originally Posted by klmken
I was looking at these at West Marine today.. Are they far superior to greased hubs? I am geting readt for a trailer rebuild....
Ken
Ken
You can use other oils but why not get the one made for the application?
Registered User
Originally Posted by cig1988
Downside of the wet hubs is if you blow a seal your screwed. If you notice the larger fleet trailer will have grease.
If you're out blowing seals, you have bigger problems than trailer bearings
![Wink](/forums/images/smilies/wink.gif)
Gene in NC
08-21-2006 09:27 PM
