Chevy truck brakes
Old 04-04-2007, 12:27 PM
  #31
Originally Posted by bouyhunter
Damn thing only has 55K on the dial, and is in great shape.
Still probably only worth 4-5K if I'm lucky.
$2000 in brakes is a pisser. It's been a good reliable truck. (5.7). Like I said just a "beater", and I don't want to invest anything in it, but I need to keep it running for the time being.
Do I need to bite the bullet and do the work myself?
It should not cost 2k to redo the back lines.
Should only be 300 bucks max- but do BOTH sides.
Wannabe
wannabe is offline
Old 04-04-2007, 05:00 PM
  #32
bouyhunter's Avatar
Thanks for the replies to this guys.
Well, it's definately got to be the line - I can wiggle it around right where it attaches to the drum.
wannabe - I think you have to replace both lines, it appears to be a "Y" connection to the rigid line on the frame rail.
So, by the time I get it towed to a shop, and pay for the repair, I'm into it for $400-500.
That's probably cheaper than the penance I would have to do for all the cussing, swearing and throwing of things I'd be doing while working on it.
bouyhunter is offline
Old 04-04-2007, 05:41 PM
  #33
get the tech/mech to use a tech2 scanner and ''park the valves'' in the abs unit after he cycles them ,then bleed the brakes with a power bleeder ,that should fix it ,also ck the abs sensors for rust as that will give false readings to the abs unit too
dmaxx3500 is offline
open87
7
10-16-2006 06:19 PM
Lmarth
12
01-07-2006 04:22 PM
phughes69
05-26-2004 05:36 AM
dyno
6
09-19-2003 11:43 AM
srpbaer
3
06-03-2003 08:17 AM
Quick Reply: Chevy truck brakes
