Acetone added to your fuel tank? (gas or diesel)
1 Post
Re: Acetone added to your fuel tank? (gas or diesel)
I run my plane's Turbo Inlet Temperature at 1650 degrees F which is the factory recommended temp for best performance. At 1651, lights start to flash.
My other plane's recommended temp was 1550 max.
The point is not all are the same.
Menace,
I noticed this morning on my way in that max EGT is set to alarm at 1350 degrees and it runs at around 650 degrees cruising at 75 mph. Just FYI.
Ben
Ben
point92mach
Chris Craft
5
07-19-2007 12:19 PM
