Best Place To Buy Truck Tires Online >
Old 08-29-2006, 05:14 AM
mama tryed's Avatar
Default Re: Best Place To Buy Truck Tires Online
Originally Posted by Jassman
Mama, looking for some larger tires to fill my wheel wells of my 07 F350 dually. The stock tires are 245-75-r17's. want to keep the same wheels. The stock tires are a BF Goodrich rugged trail TA. Something in the same line, good street tire for towing and occasional pulling trailers on dirt or jobsites. thanks Jeff.
It's going to be tuff to find anything bigger and still keep the same width for the back duals, unless you use some sort of spacer between the back rims, the 245/75 is as big as we carry in a 75 series tire. The BFG, 10 ply, would run around 119.00 plus freight.
Mitch
mama tryed is offline
Old 08-29-2006, 05:31 AM
mama tryed's Avatar
Originally Posted by cuda
Does Goodyear make their ATS in LT 275/70R18? I had that tire on my 99 F150, they had good grip offroad, not too loud, good gas mileage, and as I recall, I got over 80k miles on them. The tires I have on my 350 are more just street tires, I want something with a little more grip.
80 thou on ATS's,,you the man!! thats fantastic!! We stock them in a 275/65R18 but not in the 70 series. they would run $195.00 plus freight in a 10ply black. If your 350 has duals,I'm not sure if that would work for ya.
It's the same deal as Jassman,, the inside spacing on duals is critical, if they are to wide and rub together especially loaded,, they won't last across town!!
I can give you the spec's on that tire, O.D. & width if you want to call me, I don't have that info here at home.
Mitch
800-231-2295 ext#129
Mitch
Old 08-29-2006, 05:47 AM
mama tryed's Avatar
Originally Posted by rouxsterre
I have a 2004.5 4x2 Ram 2500 long-bed ( Cummins ).
Got OEM Michelin road tires 265 70 17's . . . .
I would like some nice Coopers.
Quiet = good. Slippery ramp traction = good.
No off-road to speak of.
MAMA TRYED ? ? ?
< Yeah that's right. I'm hijacking this thread for my own purposes. >
Cooper makes a good Tire but we don't stock them, we inventory around 400,000 passenger & light truck, mostly for the OE market. Your Michelin AS's are a great tire, but for some reason its the only 10 ply that Michelin makes in that size. BFG makes the Rugged Trail T/A thats a 10plybut thats about it. It would run around 149.00 plus freight.
If an 8 ply would work for ya, you could move up to a 285/70R17 and have a few more options.
Old 08-29-2006, 06:07 AM
Yes there are great prices on line, but the shipping kills the deal. This is what I have found. But sometimes you have to get them online because no one has specialty tires in stock and it takes them for ever to get them
enticer is offline
Old 08-30-2006, 08:02 PM
mama tryed's Avatar
usually around 10.00 to 15.00 per tire,, depending on the weight of the tire
Old 08-31-2006, 04:38 AM
Jassman's Avatar
If an 8 ply would work for ya, you could move up to a 285/70R17 and have a few more options.[/QUOTE]
Mitch how is an 8 ply vs the 10 I have on the dually now. What is involved in adding a spacer and will it effect anything towing, and or drivability. If this doesnt work, do you sell wheels and tire combo's I love the truck but want to fill the wheel well 1-3", prefer just the tires and happy with the stock wheel. Thanks Jeff
Jassman is offline
Old 09-01-2006, 05:39 AM
mama tryed's Avatar
Mitch how is an 8 ply vs the 10 I have on the dually now. What is involved in adding a spacer and will it effect anything towing, and or drivability. If this doesnt work, do you sell wheels and tire combo's I love the truck but want to fill the wheel well 1-3", prefer just the tires and happy with the stock wheel. Thanks Jeff[/QUOTE]
Jeff,
I don't think anything bigger will work with your rims, and here's why I'm saying that,,
your 245/75R17's are 9.7 inches wide and 31.5 overall diameter on a 7inch rim
a 265/70R16 is 10.7 wide and O.D. is 31.8 inches and calls for a 8 inch rim
a 285/70R17 is 11.5 inches wide and O.D. is 32.8 inches on a 8.5 inch rim
We don't stock wheels or spacers,, give Buck183 a call maybe he has some other ideas, he's in the lifting, lowering, wheel's, business or maybe someone else will chime in with other ideas. Maybe Bag it, and lower it the 2 or 3 inches your looking to fill. I hope this helps you!! Mitch
Old 09-01-2006, 06:22 AM
Forum Regulator
Sydwayz's Avatar
Received 1,255 Likes on 548 Posts
Jeff,
I would suggest checking out www.ricksontruck.com
They are super nice folks, and one of the girls there even gets on OSO once in a while. Going to a 19.5" wheel will give you better than stock towing, without the 22.5" price and shimmy while towing/turning.
I've talked with Rickson at length a few times. They reject 75% of the tires they get. They like to sell wheel & tire packages. They balance and true the tire to closest to round specs they can; which I have not heard of anyone doing. They even balance the dually wheels/tires together, and mark them so you can install them the same way.
Sydwayz is offline
Old 09-01-2006, 07:17 AM
Jassman's Avatar
Thanks Mitch and Sydways, I will check it out. Jeff
Jassman is offline
Old 09-14-2006, 06:00 AM
cuda's Avatar
Mitch
Mitch
I want to stay the exact stock size. What other tire would you suggest for the use I stated above. Btw, it's a SRW.
Attached Thumbnails Best Place To Buy Truck Tires Online-7-16-2005-001-small-.jpg
cuda is offline
Quick Reply: Best Place To Buy Truck Tires Online
