Anyone have a Dodge Ram 1500?
Thanks...personally I don't like how the GM's look but what the hell...its just a work truck. Thanks for the advice.
My 99 dodge quad cab 4wd w/360 and 3.55gears got 8.5 to 10 mpg empty running back and forth to town. First time I towed the boat I just about flipped out when I drove 110 miles and the low fuel light came on (22 gallons!!!The 360 seemed to have no bottom end tq whatsoever,the truck couldn't stay in lock up or even overdrive EMPTY if wind was blowing.It took 35 seconds stock to hit 55mph with my 7000lb boat and trailer behind it. I re-geared truck to 4.11 gears myself,took the 265 load range b or c stock tires off and put 245 load range e-'s on it,modified the exhaust,put synthetic oil in everything,added a k/n air cleaner housing and truck was night and day different. It got around 11-12mpg empty after the mods and actually pulled pretty good. It would then get 8-10 mpg pulling boat in overdrive at 70mph on flat ground,Smitty
I Have An 02 With 100k Miles On It And Other Than The Paint Issue That I Am Having I Love The Truck. Have Yet To Notice Any Trouble With The Tranny Or Anything Else. Check The Truck For A Chitty Paint Job.
17HWY 14 CITY
10 WHEN PULLING THE BOAT
17HWY 14 CITY
![Frown](/forums/images/smilies/frown.gif)
17HWY 14 CITY
10 WHEN PULLING THE BOAT![Frown](/forums/images/smilies/frown.gif)
17HWY 14 CITY
17HWY 14 CITY
17HWY 14 CITY
Originally Posted by gotime34
17 HWY?? Thats what I'm looking for. I'm not pulling the boat with this truck...Just driving long distances (200 miles tops) I'll check the paint if I start looking. Most of the problems you guys mentioned seemed to be with the late 90's model. Maybe a lot has changed with the newer trucks.
i have an 02 4wd with the 4.7. i should have waited to get the hemi. i got have got the 5.9 but i was also hearing of tranny problems with that. i didnt hear anything with the 4.7. a problem i had was a just replaced the ujoint in the rear. i also had a problem with the check engine light. i did get it to go off but it took a little playing to figure it out.i was a fuel pressure valve and i was told that that was happening on alot of dodges. anyone else have that problem?
I got a 2004 1500 4wd with a hemi motor, Black slt , $20,000.
Its one hot truck.
it gets 14 city and 17-18 hwy. its got 46,000.00 miles on it.
Mike
732-267-4080
Its one hot truck.
Mike
732-267-4080
2014 OPA-APBA National Champion Class 7 .Hauling Trash 725.
young-gun
1
10-25-2008 11:31 AM
