Questions on a 2006 GMC and Dodge >
Old 10-31-2006, 07:40 AM
Default Re: Questions on a 2006 GMC and Dodge
Thanks rbr238, no matter if you have owned them or not, these guys still don't wont to here it. I have 130k on my 02 dmax, no problems just came off a 2500 mile run. Did you read where drgnryder said i was dreaming if i thought a dmax would outrun a cummins, and in the same sentence he tells that his friends (dmax) will bareley pull on him. I know there is problems with all just some are no stop problems, such as with the 6.0 ford, strong truck they just don't last if your out here using them to haul heavy loads. My buddy took his Dodge to used car lot the other day to trade it, the guy told him he couldn't give him to much for it because it was a dodge. He asked him what was wrong with that, and he told him that, owning a dodge is like having a black girlfriend, they are fun to ride you just don't won't no one to see you with them. This is a true story, and i am not racist by any means.
DOUBLE J is offline
Old 10-31-2006, 10:02 AM
SORE MEMBER
Wobble's Avatar
Originally Posted by Catmando
I read a post on a Dodge Cummins forum(forgot which one) where this guy drove a 2001 2500 from Houston to Billings, Mt. He picked up a triple dually gooseneck trailer with a 36,000lb. load on it and drove it to somewhere in Alaska. Total weight if I remember correctly was about 41,000lbs.
There is a reason the big rigs use inline six cylinder diesels; they have the highest torque at the lowest RPMs. The Cummins also has 30% fewer parts than the Powerstroke and the Duramax, so more miles can be put on it before teardown and it gets better fuel mileage as well.
Gale Banks built a Cummins Dakota with 750hp and 1300ft.lbs torque that set the fastest speed in its class at Bonneville; 221.138mph. And when he detunes it to drive it on the street it gets over 21mpg!
I believe the main reason the big rigs use straight sixes is that they make it easy to replace the piston and jug together, head and oil pan off, new piston and liner and off you go. V8's typically dont lend themselves to this arrangement.
Wobble is offline
Old 10-31-2006, 05:18 PM
GLH
GLH's Avatar
Just got a 2006 GMC Crew Cab 3500 Dually Duramax and Love it.
It replaced the 2005 Chevy Crew Cab 3500 Dually Duramax that theives loved also it seems.
I pull a 42 Cigarette Tiger with it and it does the job stellar.
I have no idea about Dodge.
The old and the new
Attached Thumbnails Questions on a 2006 GMC and Dodge-launching.jpg   Questions on a 2006 GMC and Dodge-mill2.jpg
GLH is offline
Old 10-31-2006, 07:36 PM
Great looking setup GLH, mine looks identical to your old one, but two wheel drive. I've enjoyed every minute of mine, we even take it on family vacations as well. Is the motor in the bed of the truck what you run in your cig.
DOUBLE J is offline
Old 11-01-2006, 07:55 PM
GLH
GLH's Avatar
Originally Posted by DOUBLE J
...Is the motor in the bed of the truck what you run in your cig.
One of them...
GLH is offline
Old 11-02-2006, 09:37 PM
The d max is a refined drag motor...just now coming to life with some real after market mods....currently starting to surpass dodge with leaps and bounds...we have been hearing some very unreal numbers here and there....they seem to be true....look at this valve train..reminds me of jessel.....the whole motor is like this..I was suprised..
Attached Thumbnails Questions on a 2006 GMC and Dodge-dscn3290-large-.jpg   Questions on a 2006 GMC and Dodge-dscn3290-large-.jpg
Byrdman is offline
Old 11-02-2006, 09:46 PM
here..sorry
Byrdman is offline
Old 11-03-2006, 09:23 AM
SORE MEMBER
Wobble's Avatar
Sooo, what are you up to with that motor?
Wobble is offline
Old 11-03-2006, 09:31 AM
Forum Regulator
Sydwayz's Avatar
Received 1,249 Likes on 542 Posts
Originally Posted by GLH
One of them...
Something wrong with it already?
Sydwayz is offline
Old 11-04-2006, 09:23 PM
Building madness.....getting away from old lady in shop
Byrdman is offline
Quick Reply: Questions on a 2006 GMC and Dodge
