What Trans Fluid for My Allison ??
lots of guys are using trans syd on www.dieselplace.com allison oem trans section and somebody said to go to the allison web sight.....but there are a ton of guys using it....also it seems to cost 155.00 to 200. for 5 gallons...and they say the way to flush is do it through the return line disconnect method....they say you do not have to drop the pan and do the filter unless 25g miles...or rebuild....at the rate I change my fluid...i think I will keep the dextron....also they said the dex 3 is being discontinued soon....and going to dex VI...
Changed my trans fluid for the first time not too long ago and have started using Amsoil. My Dad is a distributor, so I can buy it at cost and I think it is a good product. We shall see. I'm putting 8-10k miles a month on my '05 Allison, pulling a 40' flatbed and loads up to 15k lbs., so I'm hoping it performs as advertised.
http://www.modernoils.com/ATD_Torque_Drive_Fluid.html
