Help With Utility Quad and Rhino
#31
Registered User
Since you already have an ATV, why not buy a nice used Jeep or something along those lines? You can do alot more with it as far as pulling/towing/etc., not to mention driving it on roadways legally.
If you have to buy an ATV, Polaris.
#32
Narrowed the quad purchase down to the Honda Rancher 420 and the Yamaha Big Bear 400. Any opinions on either. The Rancher is EFI, Big Bear is carb. Other than that, they look pretty much identical. Big Bear comes stock with ITP Mud Lites. Price is about the same. The Yamaha is a little cheaper and I can save a few more bucks if I buy the Rhino at the same time. Opinions?
Mike
Mike
One of the most important factors is how you feel the service will be from your dealer. If something does go wrong you need someone that will be there for you.
#33
Drive to arrive alive!!!
#34
Check out the richie bros auction, thats going to happen in houston, registration is on may 27, and the auction starts the 31st I believe. I saw at least 3 or 4 of those utility vehicles lined up to sell. www.rbauction.com
#35
I thought the Rhino was a true 4x4 in the "4wd lock" mode. We are also concidering one to replace a cheap 4x2 we bought at sams club a while back
#36
Based off the reading I've done and the way mine drives I am lead to believe that the rear end is locked in 2wd too. The front is open unless locked though.
Buck
#37
#38
I was plowing snow last week with it, 6' plow in low range, can't stop it.
My buddy just bought the new FI Ranger. The benefits are, its a 3 seater, you can enter from either side (the rhino has a console), the fuel inj. is great, turn the key and go, no choking.
The polaris is wider with wider tires, the rear is open, but can be locked by pushing a button. The polaris is noticably beefier too.
For around open areas and for work, the polaris. For flying around the trails, the rhino.
#40
After looking at atv's all weekend, I have decided to buy the Rhino 660 in camo and keep my YFZ 450 a little while longer. Here is what I learned:
1) Most feel that Artic Cat is junk and Polaris is only a step or two behind. Seems to be a love/hate relationship with Polaris.
2) Kawasaki Mule is the budget king and is a very reliable vehicle.
3) Kubota RTV is best for heavy work especially in diesel flavor.
4) Rhino 450 - I'm not really sure why they even make one.
5) Rhino 660 - Most popular for hopping up and seems to have best performance out of the box, so far.
6) Used side by sides are nowhere to be found.
7) They are all overpriced.
Mike
Mike
