How to protect boat from tie down strap abrasion???
OSO Moderator
![Exclamation](/forums/images/icons/icon4.gif)
I just bought some tie down straps from Warparty36 (thanks - they're awsome).
I want to get some type of protective pad. When I will be stapping down the transom, the strap will be contacting a painted area and rubbing my K-Plane. I don't want to damage the paint. Besides wrapping a rag around the strap, what can I use to REALLY protect the boat?????
Strap size is 2" wide.
Thanx!!
Thanx!!
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
Forum Regulator
Bill, I fold the 2" strap in half, and send this portion though the gap between the K-plane plate and the K-plane base on the transom. I have been doing this for several years with WarParty36's straps, and it has worked well for me. As for touching the boat, how about finding a plastic sleeve that will clip over the lower portion of your transom loop that will move the strap's attach point out an inch or more.
The only other suggestion I have, is to wrap the ratchet strap with carpet, and secure it in place with zip ties. You may consider moving the trailer eyes to a place that would cause less trailer boat/strap interference
OSO Moderator
BTW: I hope your felling better and will be back on the boat soon!!!!
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
Bill, walmart has the seat belt covers that work great for that, they hook around the strap and velcro together. I also have some of the 20 mil film if you want to stick a couple pieces in the painted area. call me on my cell 410-746-0020..rob
Forum Regulator
I send the strap through the outer opening between the K-Plane and Backing Plate. This slit is about 1.5" deep, and the folded strap sits in there perfectly. There is no need to feed the hook through there, as the strap comes in from the side.
The AT has some SS outer backing plates on the transom loops. I have a specific way that I hook the strap that the only point the hook touches the boat is on the SS backing plate.
I may have some pics back at home when I get out of the hospital.
Forum Regulator
Sydwayz
6
06-24-2007 05:11 PM
Strip Poker 388
09-17-2006 09:55 PM
Marginmn
08-19-2004 10:15 AM
