Distribution tow bar?
JB Marshall
J.B.
Did you purchase the 382 from Pt Clinton, Ohio? Looks like one at J&J sales.
I pull a 382 with an F-350 and weight distributing hitch. MUCH nicer ride, MUCH less bucking and MUCH safer. The 382 is #10,400 dry. Eagle triple axle steel trailer is #3000 on the nose. Add a little fuel and gear, you are easily in excess of #14,000.
Go with the WD set-up. You will not regret it. Agree a dually will be better and safer for towing this heavy.
RedDog,
No on Port Clinton. Thanks for the confirmation on the weight distribution hitch. Do you experience much sway when going down the highway and passing 18 wheelers?
Best thing ever ! I tow a 382 with a F-350 06 dually. The weight rating of the truck and hitch without a WD hitch is far exceeded by a 382. It may tow ok but an accident and a lawsuit will be ugly. I thought mine towed really well before I installed a Reese Tow Beast. It really changed the ride..much different with the WD hitch. I heard launching was a pain but I have not found a problem.
1 Post
Minimal sway around semis, very predictable response to the draft. Otherwise sway is non-existent, even in higher wind conditions. Key is tongue weight set-up. Not sure how a F-250 SRW would be, though.
Here is the one I've used for the past 2 years with great results. It can be used with boat surge brakes. Also mine is for sale as I just bought a new truck.
http://www.equalizerhitch.com/produc...patibility.php
I'll take $300.00 + shipping. This system weights around 100LBS. It includes: 90-00-1200 system, 95-01-5950 Pole Tongue Adaptor, 2 5/16 25000LBS Ball, 90-02-4100 3" drop/7"rise shank, and a 90-02-4200 4" drop/8" rise shank.
Boatman, is your setup sold?
And can I ask why your selling it?
Just saw above that you got a new truck.
