Question for 2001 -2006 Chevy owners
I am retrofitting the large manual extending tow mirrors on my 02' 3500. Does the factory install these with heat on its own switch. Also does the heat stay on for a set period of time like most rear window defrosters. Thanx
SORE MEMBER
1 Post
they will physically fit, but the wiring is different, go to the www.dieselplace.com site someone figured out the wiring pin outs for the switch in the exterior section I believe
I can't accurately comment on the O2 year mirrors, I have an O3, with heated mirrors. I can tell you the answer to your timing question, yes, the heaters are on a timer, just like the rear window defrost. The switch resides next to the rear defrost switch. I would expect that you could easily retrofit heated, extendable mirrors to your truck. dieselplace.com, exteriors section.
puder
14
03-06-2007 01:23 PM
Viper31
3
12-17-2006 11:13 AM
