Chip for F-450 SD ??????
www.innovativediesel.com
Real world numbers are 5.9 pulling 38 Fountain or 24 foot high boy trailer, and 9.5 -10 empty. F-450 dually 2WD diesel and it can be purchased cheap. call me 336 214 6900
Do you have the job 2 front air dam? On trucks built after July, a 5 inch air dam comes under the front bumper. The other ones are about 2 inches. Big difference in size. The newer, bigger air dam will give you 1 mpg. at 70 mph. Cost is about 80 bucks. I can order it for you if you like.
910-787-4101
910-787-4101
F-450
Mine is a 08 Cab Chassis with a service bed and a crane. I see from 8 to 11 mpg..stinks. The truck weighs about 13K all the time. I did change the gear set to 4:30's...My '06 6.0 gets 10 towing a 382..stock!
That's about right...I pulled my 43 Nortech with my 07 6.0 from Ft Meyers to MS and ave. 10.2...65-74mph..4.10 gears..All stock, except air intake, and exhaust. Just wanted to see what the diff. was with out the tow tune in. Jeff
910-787-4101
910-787-4101
chuckd1025
23
01-07-2008 02:15 PM
