Surge Disc vs Electric o/Hydraulic
Is Electric over hydraulic conversion (from surge drum) worth the money? I'm estimating $1200-1400 for the module/resevoir, break away battery, rotors, and calipers. I've had Kodiak surge disc brakes on my previous trailer and was quite happy with them. I think I paid about $160 (single braking axle). The reverse solenoid did look a little hoaky IMO and did seem to rust quickly. The only benefit to elec/hydraulic I can anticipate would be if the trailer got squirly you could manually brake the trailer at the controller in the tow vehicle to straighten out the trailer. Thoughts?
1 Post
EOH is like getting your first microwave. Did the conversion last year and would never settle for nothing less. And yes you can slide the trolly to tighten the slack.
Registered User
If nothing else...
If you're going down a long grade and overheat your brakes, you have no "surge" to actuate your surge brakes.
Other than that, the control difference is dramatic. Surge is crude & clunky. EoH is an extension of your trucks brakes- set up properly, you shouldn't know it's there and your truck will stop like nothing's connected.
Get brakes on all axles.
I personally have never towed with electric over hydraulic, but considered swapping my current surge setup out for it because I have never ever heard of somebody that regretted it. Everyone says E/H is the way to go.
When I ordered my new trailer, I specified electric over hydraulic. They added only 100.00 to the price. After using it several times with large boats on it I'd say it would have been worth it at 1000.00 more. My smaller, 25' trailer has surge brakes and it's quite a difference, I certainly don't feel as though I'm in control with that setup.
One of the best mods I have ever done.....triple disks...I think it will stop quicker with the boat. You also have braking in reverse going down real steep ramps. If it starts dragging the truck, just reach down and give it a little break on the box.
Yes, I would never buy another trailer with out. But how far do you trailer? If its just a couple miles to ramp, maybe money better spent elsewhere. If you tow greater distance or like to travel, would upgrade.
One thing for sure, there is no shortage of goofballs who pull out in front of you when trailering - drive defensively!
The BAD Guy
![Thumbs up](/forums/images/icons/icon14.gif)
YES elec/hyd is the only way to go. I had someone pull out in front of me and IMO if I didn't have them I don't think I would have been able to stop in time. The truck does stop better when the trailer is hooked up then when not. Do it!
